Activity Forums Adobe After Effects Expressions Using loop expressions in conjunction with other expressions
  • Using loop expressions in conjunction with other expressions
    Posted by Seymour Frost on May 17, 2022 at 3:11 pm
    Hello! Is there any way to use a loop expression on a property that already has an expression on it? The problem I came across was in building a simple rig that used an expression on the scale property to maintain the volume of an object. But then, when I went to put an loopOut() expression on this property, it would not loop.
    on scale:
    var x = value[0];
    var xFactor = (100 – x);
    var y = 100 + xFactor;
    [x, y];
    and then to loop the set of keyframes I made, regardless of whether I needed to move the keyframes in the comp:
    loopIn() + loopOut() – value;
    I’ve tried redefining the value as the returned array from the first part of the code, but that didn’t work. I thought that the loop expressions simply read the value of the keyframes that were set, and thus wouldn’t be impacted by any expressions making calculations on every frame. Am I just fundamentally misunderstanding something?
    Seymour Frost replied 4 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 17, 2022 at 4:18 pm
    I think you just need to stick the result of your loop calculation into a variable and use that instead of value in the other part of your expression, like this:
    val = loopIn() + loopOut() - value;
    x = val[0];
    xFactor = (100 - x);
    y = 100 + xFactor;
    [x, y];
  • Seymour Frost
    May 17, 2022 at 5:05 pm
    Thanks so much, Dan! That, of course, worked brilliantly.
