Using Layer control to select particular layers.
Hey there, I’m trying to make a Layer Control box that can switch which layers are visible (say flip the selected layer’s opacity from “0” to “100”)
I’m also trying to control the layers in a pre-comp, from a master comp.
For example:
I have a Master Comp with a Pre-Comp imbedded. And a Null object (named “Shape Selector”) with the layer control.Inside the Pre-comp, I have the layers I’d like to switch between. (“Circle”, “Square”, and “Triangle”)
Is an expression that lets me switch between the shape layers in the pre-comp, from the Master Comp, even possible?
Thanks very much in advance =D
