Activity › Forums › AJA Video Systems › using kona captured footage on a non-kona computer?
  • using kona captured footage on a non-kona computer?
    Posted by Joseph Farris on June 7, 2005 at 3:27 pm
    I have captured DVCPRO HD footage using the Kona HDSDI input using their Kona DVCPRO HD Codec. My question is… Is it possible to take that footage on a Firewire 800 Drive to a different system and playback and edit the project? It seems that when we bring the project to a system without the kona board it gives us memory errors. Anyone have any experience with this? Thanks for your help.
    Joseph Farris
    Director of Photography
    Visions of Light, Inc.
    Office: 312-829-8244
    Pager: 800.808.8244
    Mobile: 630.306.8244
    Fax: 630.690.7678
    http://www.visionsoflightinc.com
    joe@visionsoflightinc.com
    Jerry Hofmann replied 21 years, 3 months ago 4 Members · 7 Replies
  • 7 Replies
  • Fred Connors jr.
    June 7, 2005 at 6:58 pm
    We do it all the time.
    It works just fine.
    Fred
  • Jerry Hofmann
    June 7, 2005 at 7:57 pm
    Wonder if loading the Kona drivers on that second mac might make a difference?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Fred Connors jr.
    June 7, 2005 at 9:08 pm
    Don’t need the Kona Drivers. If you use any DVxxxx or uncompressed codec.
    Fred
  • Jerry Hofmann
    June 7, 2005 at 10:17 pm
    Since no card, no need. This is really something that used to need a second work station card for second workstation a while back.
    Jerry
  • Christopher Tay
    June 8, 2005 at 1:00 pm
    What about those clips captured with the Apple Uncompressed 4:2:2 8bit or 10bit codec, which apparently is installed with FCP ?
    Is there a way to copy the codecs over to the other Macs that doesn’t have FCP installed ?
    -chrispy
  • Fred Connors jr.
    June 8, 2005 at 1:33 pm
    “What about those clips captured with the Apple Uncompressed 4:2:2 8bit or 10bit codec, which apparently is installed with FCP ? Is there a way to copy the codecs over to the other Macs that doesn’t have FCP installed ? ”
    We move the files machines that do not have KONA2 cards but they do have FCP.
    I am sure you can move the codecs, but I am not sure if that is legal.
    Fred
  • Jerry Hofmann
    June 8, 2005 at 3:51 pm
    It’s most likely not legal… but then, If Apple allows you to put Compressor on other Macs just to create a render farm for Compressor and Shake…
    Jerry
