Activity › Forums › Blackmagic Design › Using Intensity Pro to Capture from Betacam SP deck.
  • Using Intensity Pro to Capture from Betacam SP deck.
    Posted by David Jolosky on February 15, 2008 at 1:07 am
    Hi all,
    Just looking for confirmation that I can indeed come from Beta SP via component cables to the Intensity Pro (using BNC to RCA Adapters) into Final Cut Pro.
    Should do the trick yes? I’m trying to help a client out of a jam with some Beta Tapes. I have the Intensity Pro and a borrowed deck, but wanted some piece of mind before I pick up cables and adapters.
    Thanks much.
    David Jolosky replied 18 years, 7 months ago 1 Member · 2 Replies
  • David Jolosky
    February 15, 2008 at 1:46 am
    Thanks so much for the confirmation. Off to pick up some cables. Cheers!
    david jolosky, visual communications || design || construct || interact
  • David Jolosky
    February 16, 2008 at 5:14 am
    Just a follow up. Capture from Beta over component via Intensity worked like a charm! Thank you.
    dj
