Activity Forums Adobe After Effects Expressions Using Inertial Bounce on Objects in a precomp
  • Using Inertial Bounce on Objects in a precomp
    Posted by Oskar Ziemba on September 3, 2014 at 12:28 pm
    Hello dear Experts,
    i am trying to use the inertial bounce expression on objects in a precomp. The precomp itself is scaled in a master-comp and i want the objects in the precomp to bounce. So my thought was i have to look at the worldcoordinates of the precomp in the master-comp and then apply the inertial bounce in the position of the objects in the precomp. But – you guessed it – i am stumped at how to achieve this. I hope my explanation is sufficient.
    Many thanks,
    oskar
    amp = .1;
    freq = 2.0;
    decay = 2.0;
    n = 0;
    if (numKeys > 0){
    n = nearestKey(time).index;
    if (key(n).time > time){
    n--;
    if (n == 0){ t = 0;
    }else{
    t = time - key(n).time;
    if (n > 0 && t < 1){
    v = velocityAtTime(key(n).time - thisComp.frameDuration/10);
    value + v*amp*Math.sin(freq*t*2*Math.PI)/Math.exp(decay*t);
    }else{
    value
    Oskar Ziemba replied 11 years, 12 months ago 1 Member · 0 Replies
  • 0 Replies
