Activity › Forums › Apple Final Cut Pro Legacy › Using HD clips alongside Mini DV in a Standard Timeline
Posted by Dominic Elliot on June 24, 2010 at 1:58 pmI have one bit of film that was made in HDV, and I want to use it with the rest of my material, which was filmed in standard mini DV PAL. It gets distorted when I put it into the timeline – how can I convert it in such a way that it joins the other footage seamlessly? Would be hugely grateful for some help and feedback!
Dominic
Dominic Elliot replied 16 years, 3 months ago 2 Members · 4 Replies -
Tom Wolsky
June 24, 2010 at 2:26 pmGet’s distorted how? What’s standard mini DV PAL? Is it 4:3 or 16:9? If it’s the former the material will appear letterboxed, if the latter, the HD material should just scale down to find the widescreen format.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Dominic Elliot
June 24, 2010 at 2:45 pmThanks Tom for responding to my call for assistance!
The HD and the mini DV clips were both filmed in 16:9. When I drop an HD clips into the timeline with the other 16:9 DV clips, it shrinks itself into the frame. I’ve also noticed that it appears as a much wider looking 16:9 than ‘normal’ 16:9. Up till now I’ve been managing the problem by zooming in on the clip so that it fills the entire frame, but this is not ideal.
I have also tried right clicking on it and selecting ‘remove attributes’ but all this does is make a very small adjustment in the width of the clip but does not solve the other distortions.
It also flicks outwards every time I put a title or subtitle over it, so it ends up zooming in and out on playback!!
Tom Wolsky
June 24, 2010 at 2:59 pmWhat kind of HD is this exactly? What are the specs of the original? Can you post a screenshot of what you’re seeing?
Are you looking at the rendered output of the titles on a widescreen video monitor?
All the best,
Tom
Dominic Elliot
June 24, 2010 at 3:37 pmYes, you’re right! My mistake – the problem was that the original HD had been exported as a quicktime and then reimported. The original HD material renders into the timeline without any distortion.
Many thanks for your help!
Dominic
