Activity Forums Apple Final Cut Pro Legacy Using FCP On MacPro without Monitor
  • Using FCP On MacPro without Monitor
    Posted by Blue Melnick on April 8, 2010 at 12:21 pm
    Hi all,
    I’m trying to use FCP (or even just compressor for that matter) on a MacPro that doesn’t have a monitor hooked up to it.
    The problem is, when I try to launch it, it tells me that I have no VRAM installed on the system… which isn’t really true as there is a 256MB ATI Radeon HD in it, and when I go into about this mac, it says 256mb vram total.
    Any thoughts on how to get around this? I’m trying to use the MacPro and an exporting from FCP and compressor computer.
    Blue
    Scott Davis replied 16 years, 5 months ago 3 Members · 2 Replies
  • Doug Beal
    April 8, 2010 at 12:47 pm
    You might look at a KVM switch to have a monitor connected when FCP boots then switch monitor to whatever station after the task is assigned. I’m assuming you are driving the headless station with share screen?
    without a monitor connected to the DVI port FCP assumes is no GFX card installed.
    Doug Beal
    Editor / Engineer
    Rock Creative Images
    Nashville TN
  • Scott Davis
    April 8, 2010 at 2:11 pm
    Or you could buy a really cheap monitor to hook up.
    Scott Davis
    View Scott Davis's profile on LinkedIn
