Activity › Forums › Adobe After Effects Expressions › Using extendscript to collapse layer properties (like clicking on the triangle or using Ctrl + tilde key ~ )
  • Using extendscript to collapse layer properties (like clicking on the triangle or using Ctrl + tilde key ~ )
    Posted by Ababei Stefan on June 1, 2019 at 8:53 am
    Let’s suppose that you add a text layer with a “Animator” to the timeline using extendscript. The layer it’s created and added to the timeline but all the Animator properties will be revealed. Is there a way to collapse all those properties using extendscript? Maybe a menu command ID ? Thank you.
    Ababei Stefan replied 7 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    June 1, 2019 at 5:05 pm
    Try duplicating the layer and deleting the original.
    Dan
  • Ababei Stefan
    June 2, 2019 at 7:45 am
    Greate, it works.
    About a year and a half ago I started my first scripting project, a steep learning curve,
    I found your posts and tutorials very helpful. Save my had baging against the table.
    Thank you!
