Activity Forums Adobe Encore DVD Using Encore to create a DVD from an Avid Sequence
  • Using Encore to create a DVD from an Avid Sequence
    Posted by Mark Suthard on February 3, 2006 at 5:40 pm
    What is the best and fastest way to author a DVD using Adobe Encore from an Avid Sequence? I was testing Encore out with a 36 minute video edited in my Avid Xpress Pro system. I exported the sequence to a Quicktime Movie and have been transcoding the sequence for a couple of hours only to get an error message. Is there a fast way to do this or does Encore really only work with Adobe programs?
    Mark Suthard replied 20 years, 7 months ago 6 Members · 8 Replies
  • 8 Replies
  • Tim Kurkoski
    February 3, 2006 at 5:50 pm
    Encore 1.x doesn’t work especially well with QuickTime files. (2.0 is better with them.) If you can export an MPEG-2 file from Avid, that would be best. Otherwise, try using an AVI file.
  • Mikey W
    February 3, 2006 at 10:42 pm
    I export from Avid Xpress Pro as an AVI. Seems to work OK, EXCEPT when I’m exporting a 16×9 image. Can’t get Encore (1.5) to recognise the widescreen format. If I export from Avid as 720×576 then (obviously) Encore thinks it’s 4×3. If I export as 1024×576 then Encore won’t import the file and tells me that I need 720×576. If I’m doing something wrong, someone please tell me…..
  • Aanarav Sareen
    February 4, 2006 at 12:08 am
    Encore DVD only supports full NTSC and PAL resolutions at the moment (720*480 and 720*576) and hence the error while supporting 1024*576
    But, out of curiosity, why are you using this resolution anyway?
  • Mikey W
    February 4, 2006 at 7:44 am
    Purely out of desperation. I appreciate that it’s not correct, but my adventurous spirit got the better of me…..
  • Pentti Kakkori
    February 5, 2006 at 9:53 am
    Activate your AVI > right click > Interpret Footage > Conform to widescreen.
  • Mikey W
    February 6, 2006 at 10:50 am
    Thank you. That’s exactly the answer I needed.
  • Peter Mitchell
    February 9, 2006 at 2:01 am
    I’m using an Avid MC Adrenaline (v2.16) and have “Send to” configured to open Encore. I export and encode QT reference files, both PAL and NTSC. No problems so far with programs up to 24 min in length.
  • Mark Suthard
    February 9, 2006 at 4:57 pm
    what settings do you use when using the “Send To”? how long does it usually take to export and import your files?
