Using DVC HD in SD Sequence
I did read the exhaustive thread “Really? No One Has Seen this?” but would like to come back to one of the initial points…
My situation: project going to DVD & web, shot interviews with HPX-170 at 720-30PN, attempting to edit in FCP 6.0.1 DVC50 sequence, 720×480.
I need to re-size and re-frame certain clips at edit points. When bringing in a clip into the sequence it displays letterboxed showing in the Motion Tab/Scale = 75% and Distortion/Aspect Ratio = -50. Increasing Scale to 100% fills frame top-to-bottom (fine) and crops the sides (also fine).
Point of confusion: why does it take scaling a 720 clip at 100% to fill a 480 sequence? I assume the -50 Aspect Ration is dealing with the 960×720 actual frame size.
Side question: Am I correct in assuming that when using a DVC50 sequence (601/DV pixels) the resolution should be 720×486 for broadcast output and 720×480 for DVD?
LeeLee HIlliard
hcg1000@earthlink.net
