Using depth buffer images from LW to add DOF blur??
I’ve rendered out some Lightwave animation with a separate pass to export the z-buffer as RPFs.
What effect/process is used to use the depth buffer sequence as a controller to blur the rgb image?
Also, I note the project window lists the depth buffer files as having TRILLIONS (not millions) of colors– what’s up with that???
