Activity Forums VEGAS Pro Using Ctrl + Mouse drag to speed up video beyond apparent maximum
  • Using Ctrl + Mouse drag to speed up video beyond apparent maximum
    Posted by Sean Smith on April 26, 2010 at 4:03 am
    I’ve sped up some video by holding Ctrl while dragging from the edge of the (group of) events but it only goes so far and I’d like to speed it up further. What is limiting the extent to which I can speed up the video? Is it completely arbitrary? I don’t want to use the velocity envelope because then the video would be out of sync with the audio.
    Theo Van laar replied 16 years, 4 months ago 3 Members · 2 Replies
  • Mike Kujbida
    April 26, 2010 at 2:19 pm
    “I don’t want to use the velocity envelope because then the video would be out of sync with the audio.”
    Apologies for not understanding but, by doing the Ctrl+drag method, you’re already messing up the audio so why do you care about using a Velocity envelope too?
  • Theo Van laar
    April 26, 2010 at 9:53 pm
    “What is limiting the extent to which I can speed up the video? Is it completely arbitrary?”
    When you use increased speed (either Ctrl-dragging and/or velocity envelop) in combination with nested files, there is no limitation…
    Theo
