Activity Forums Apple Final Cut Pro Legacy Using Compressor what formats can FCP edit (apart from prores)
  • Using Compressor what formats can FCP edit (apart from prores)
    Posted by Ben Edwards on April 1, 2011 at 7:26 pm
    I have a lot of iMovie DV which I am using Compressor to transcode so it can be edited in FCP. Prores creates files 4 times the size of the original, are there any other formats I could try which FCP can edit (HDV seems to be available and FCP can edit it).
    Regards,
    Ben
    Ben Edwards – Freelance Filmmaker
    https://www.funkytwig.com
    Ben Edwards replied 15 years, 5 months ago 3 Members · 3 Replies
  • Tom Wolsky
    April 1, 2011 at 8:37 pm
    Go into Audio/Video Settings and in sequence presets check the list of available codecs. Anything in there FCP can working with natively.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • Shane Ross
    April 1, 2011 at 9:53 pm
    iMovie DV files? As in .dv? Standard definition? Then convert to DV/NTSC.
    HD? Then you can try DVCPRO HD or the Apple Intermediate Codec
    Shane
  • Ben Edwards
    April 2, 2011 at 12:58 pm
    Thanks everyone. I ended up encoding to DV PAL.
