Activity Forums Adobe After Effects using compressed media
  • using compressed media
    Posted by Joshua Stanley on June 22, 2005 at 4:11 pm
    Ok Im updating my reel, but I moved since I last put it together. I have some material on my old reel I would like top put on my new reel but I dont have the original uncompressed footage. Can I edit my compressed reel adding new footage and then outout with the same compression I used on the original without lossing quality? Any other way to reuse this footage? I should have been more careful with the original.
    Josh
    Matt Larson replied 21 years, 3 months ago 2 Members · 1 Reply
  • Matt Larson
    June 22, 2005 at 4:23 pm
    Nope. Once you bring in that compressed media, you are going to have to compress it again for delivery, so that’s like a second generation loss. Depending on how it was compressed the first time the results will be better or worse. For Example if it was compressed to MPEG-2 and then recompressed to MPEG-2 again, it wouldn’t be as bad as a 320 x 240 web video.
    I’d suggest rendering your original compressed file as an Animation Quicktime or something else lossless and use that in AE and archive it so you can go back to it again in the future without having to go through a 3rd generation loss.
    Now that said, if your original clip is a commercial or something and you just want to play the entire clip, you might be able to use some scripting for Quicktime or WIndows Media to make it link to the original clip from your new stuff. Check out the web forums here if you need help with that.
