Activity › Forums › Canon Cameras › Using Compent out of the XL H1??/
  • Using Compent out of the XL H1??/
    Posted by Delano Bryant on October 10, 2007 at 10:51 pm
    What kind of signal or image size do I get when I use the supplied HDMI breakout cable from the XLH1? too take a compent signal into FCP? Does anyone use this for capturing?
    Is that the color red you want to use?
    Todd Terry replied 18 years, 11 months ago 3 Members · 3 Replies
  • Donald Berube
    October 11, 2007 at 3:07 pm
    The Component output of the XL H1 outputs an Analog Component Y(Green), Pb/Cb(Blue), Pr/Cr(Red) 4:2:2 29.97 1080i signal.
    – Don
    https://noisybrain.com
    https://www.bosfcpug.org
  • Delano Bryant
    October 11, 2007 at 3:11 pm
    BUt that is not as good of quality as SDI? I have the KONA LH card. I can not find which connector on the card is for SDI.
  • Todd Terry
    October 11, 2007 at 5:22 pm
    [hdfilmmaker] “BUt that is not as good of quality as SDI? I have the KONA LH card.”
    HD-SDI is going to be the way to go, if you can…. although I kinda doubt your eyeballs would be able to tell if it is much superior to component.
    I’m guessing you don’t have the AJA KONA breakout box… which has direct HD-SDI BNC connector inputs and outputs on it…that’s the way we injest XLH1 video. Without the breakout box, I’m not sure how you can get HD-SDI into the KONA card. You might ask that over in one of the AJA forums.
    Even if you can get HD-SDI video straight into the card, you might look into getting the breakout box just for convenience sake (it’s a slim rack mount box with bunches of BNC connectors, XLR audio ins and outs etc… and connects straight to the card with two cables). It’s not very expensive, if I recall.
    T2
    __________________________________
    Todd Terry
    Creative Director
    Fantastic Plastic Entertainment, Inc.
    fantasticplastic.com
