Activity Forums VEGAS Pro Using “combine” audio tracks
  • Using “combine” audio tracks
    Posted by Brian on June 14, 2007 at 10:48 am
    I got tired of my audio just playing on one speaker so I changed right clicked on the timeline and selected “combine”. Is there a reason NOT to do this?
    Don Bloom replied 19 years, 3 months ago 2 Members · 1 Reply
  • Don Bloom
    June 14, 2007 at 6:56 pm
    if you have 2 channels running especially if they are set to different levels or 1 is for an on camera mic and th eother to a wireless you will get to channels showing in the timeline. If you have only 1 channel showing and thats the way you recorded it then you can either use COMBINE or select the one channel that is recorded and use that. Either way the audio will be centered.
    Don
