Activity › Forums › Adobe Premiere Pro › Using Cineform Prospect HD with AJA Xena
  • Using Cineform Prospect HD with AJA Xena
    Posted by Clayton Nolen on August 14, 2009 at 5:28 pm
    Hello all,
    Does anyone know what the advantage of using a hardware card with Prospect HD is? Cineform told me that it works best with the AJA Xena. If I understand correctly, it is not necessary to use a hardware card with this plugin, so does the extra hardware simply make it run faster? Does it enable more effects? Any help would be appreciated.
    We are running a Dell Precision R5400 Dual-Quad Xeon with 16gigs Ram Vista 64bit
    Clayton Nolen replied 17 years, 1 month ago 2 Members · 2 Replies
  • Tim Kolb
    August 14, 2009 at 11:41 pm
    The Xena card gives you conventional video/audio input/output capabilities. You can monitor via SDI and ingest formats like HDcam.
    I like my system with both CineForm and the Xena card…but if you plan on simply editing something to author to DVD or some other method of distribution other than making a master tape, Prospect works fine without it as well…
    TimK,
    Director, Consultant
    Kolb Productions,
  • Clayton Nolen
    August 17, 2009 at 2:46 pm
    Thanks Tim! I think that answers the question!
    Clayton
