Activity Forums Adobe After Effects Using CC Cylinder to create background – stuck!
  • Using CC Cylinder to create background – stuck!
    Posted by Mark Landsburger on September 7, 2006 at 12:33 am
    Hi all,
    I’ve searched through all the posts I could find on using Cylinder, but have a few other questions.
    I’m trying to use one big picture as the background along with an AE camera that will move around. I read that you are not supposed to make the “cylinder” layer 3D. Problem is, if I don’t, the camera doesn’t react to it. The only way I can seem to change the “spin” value of cylinder, but I need it to react to the camera so as it pans/moves, the bg changes.
    Any help would be greatly appreciated.
    Take care,
    Lands
    Stefan Tapper replied 20 years ago 2 Members · 1 Reply
  • Stefan Tapper
    September 7, 2006 at 5:16 am
    Leave the 3D switch unticked and it will work as a 3d object. The effect already enables the 3d property.
    Easiest way to work with the cylinder or sphere effects is to pre-compose your “texture” or cylinder-layer. This way you can modify and edit it very easy in future steps.
