Activity Forums VEGAS Pro Using Bezier Masking data to stabilize a moving character
  • Using Bezier Masking data to stabilize a moving character
    Posted by Jeff Schroeder on October 7, 2019 at 6:34 pm
    Am I missing something about Bezier Masking?
    Why can’t I take the data and apply it to PIP to get a stationary presenter?
    I have a video of a presenter and he walks back and forth in a 6 foot area as he presents his power point. I would like to tack him on as a PIP on the left side of the current slide and recenter him as he moves around. It seems I can’t anchor the mask while keeping the tracked video in a box.
    Can anyone help?
    Dell Precission 7810 with 2-Intel Xeon E5-2630, 32GB DDR4, GTX 1080 8GB, Windows 10, Vegas 15 x64, Hitfilm Pro 4 w/Ignite
    Jeff Schroeder replied 6 years, 10 months ago 3 Members · 4 Replies
  • Francois Pénzes
    October 8, 2019 at 10:46 am
    Hi Jeff
    Can you elaborate on your workflow ? What are you using (Mocha, etc..) to track you talent ? Any way for you to post a short clip of your ”travelling” talent ?
    Cheers !
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
    Cameras: Canon XF305 + Canon XH-A1
    Blackmagic HyperDeck Studio Mini
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
  • Jeff Schroeder
    October 8, 2019 at 1:10 pm
    I am using the builtin Bezier Masking whick tracks my subject just fine. Now I want to ‘anchor’ the mask and move the video so my subject stays in one place.
    Dell Precission 7810 with 2-Intel Xeon E5-2630, 32GB DDR4, GTX 1080 8GB, Windows 10, Vegas 17, Hitfilm Pro 4 w/Ignite.
  • Paul Berk
    October 11, 2019 at 10:57 pm
    If I understand correctly what you want to do. Here’s my solution.
    I tried this with Bezier Masking Track Motion. I could not do it. Track motion does not move the frame, but rather “tracks” an object within the frame so if the subject is packing back and forth within the frame, the motion track will also move back and forth across the frame. To “center” the object, you need to crop into the frame and move that crop back and forth with the subject centered.
    You can do this manually. I did it by cropping into the presenter head and shoulders and setting keyframes manually to keep the presenter in the center, then the Picture and Picture will have the presenter centered at all times. If you cannot crop into the presenter, this solution will not work.
  • Jeff Schroeder
    October 12, 2019 at 3:11 pm
    I found the answer!
    I downloaded this script Copy Mask to Crop Center.cs from https://github.com/DustVoice/VEGAS-Scripts
    and followed the instructions. It makes your moving object anchored on one part of the screen.
    Just what I needed.
    Thanks everyone.
    [Keywords to make it easier to find]
    Copy Bézier mask data
    Copy Bezier mask data
    Tracking moving object
    stabilize single object
