Activity › Forums › Adobe Premiere Pro › Using best export settings but getting bad quality video
  • Using best export settings but getting bad quality video
    Posted by Matthias Göransson on May 14, 2017 at 12:19 pm
    Hi
    I’m using what I’ve read is the best settings for export, but I’m not satisifed with the video quality. If you look closely in the upper right corner at 00:58-01:00 in the video you can see what I mean. It’s very pixely and I don’t understand why this is.
    https://vimeo.com/217371441
    I use these settings:
    Anyone know what I’m doing wrong?
    Regards,
    Matthias
    Steve Brame replied 9 years, 4 months ago 4 Members · 8 Replies
  • 8 Replies
  • Matthias Göransson
    May 14, 2017 at 4:59 pm
    Export settings is attached in the post…
  • Steve Brame
    May 14, 2017 at 8:29 pm
    Actually, the Bitrate Settings is cut off, and that’s the section we need to see.
    Steve Brame
    creative illusions Productions
    May 14, 2017 at 9:15 pm
    Sorry, my bad.
    Bitrate was constant, set on 18 this time.
  • John Pale
    May 14, 2017 at 10:25 pm
    Make sure you are using the settings recommended by Vimeo or your video will be re-encoded at their end.
    https://vimeo.com/help/compression
    That’s the best you can do if Vimeo is your destination.
    May 17, 2017 at 1:26 pm
    I think i followed all the guidelines from Vimeo, but the video still looks pretty bad compared to many other videos I think.
    The only think I’m not sure about is the “High Profile” H.264 that Vimeo recommends instead of the “Main Profile.” Where do I choose this?
    Regards,
    Matthias
  • Eric Santiago
    May 17, 2017 at 1:42 pm
    I posted something similar just a few minutes ago.
    I too am feeling the pinch on this situation.
    In the past I usually shrug it off as “web compliant” and then Im fine with it.
    But this time around, I cant understand why it is after all the work I did in Resolve.
    I am using a ProRes4444 file as master.
    May 17, 2017 at 3:12 pm
    I acctually haven’t heard about that. Is it betther than Premiere Pro somehow?
  • Steve Brame
    May 17, 2017 at 3:14 pm
    PRESETS????? We don’t need no stinking PRESETS!!! ????
    Steve Brame
