Activity Forums Boris FX Using BCC5 Open GL lens flair in FCP/Motion
  • Using BCC5 Open GL lens flair in FCP/Motion
    Posted by Adrian Charles on October 16, 2007 at 7:45 am
    Hi All
    Riddle me this?
    4:3 FCP project. sent two 10frm clips across a cut to motion to create sexy directional
    blur lens flair wipe (using BCC5 open gl lens flair). Wipe created in motion then saved.
    effect appears on FCP timeline as it should. before rendering lens flair is 4:3, after
    rendering on the lens flair is 16:9 ?
    Tried the same lens flair on fcp clip direct works fine!
    adrian
    Adrian Charles replied 18 years, 10 months ago 2 Members · 3 Replies
  • Peter Mcauley
    October 16, 2007 at 6:15 pm
    I’ll pass this along to support and ask them to see if they can reproduce the problem as described by you. It does seem rather odd that this would be happening. Is it only the bcc lens flare filter that has this problem or are any of the other filters in the package exhibiting the same issue? Is there a preference in Motion to control the PAR and if so has this been set correctly?
    Peter.
  • Peter Mcauley
    October 16, 2007 at 6:53 pm
    Hello,
    We’ve tried to reproduce this issue in house and have not been able to replicate. So … I know that you’re having a problem with your project so could you please send us your motion project (with slug media) and we’ll use that to reproduce the issue that you are reporting.
    You can send the project (zipped) to me at and I’ll send it down to QA / support to take a look.
    Peter.
  • Adrian Charles
    November 7, 2007 at 12:28 am
    Peter,
    Sorry it has taken me so long to reply to your post. I have tried the Bcc5 open GL lens flair on a
    G5 dual 2.7 PowerPC and a Two 3.0GHz Dual-Core Intel Xeon Mac Pro. both produce the same result.
    When a lens flare is applied in a Motion project, (4:3 aspect ratio) it has circular light rings which is what you would expect. if the same Motion project is placed on a 4:3 FCP timeline the rings appear oval shaped, which is not what you would expect. I have a screen grab and a motion project l could send to you if you let me have your email address.
    Great product by the way!!
    regards
    Adrian
