Activity Forums Adobe Encore DVD Using as MPEG-2 Encoder
  • Using as MPEG-2 Encoder
    Posted by Samuel Smith on July 30, 2010 at 12:05 am
    I am trying to find an encoder to fit a very specific mpeg-2 format and was wondering if Encore would be a the program for me. Here is the spec sheet I need to be able to match –
    Encoding . . . MPEG-2
    Preferred. . . . 18Mb/s
    Scanning. . . 480 60i (upper field first)
    Pixel Aspect Ratio. . . . . . . . . . . 0.9
    Aspect Ratio. . . 4*3
    Chroma. . . . . . . . . . 4:2:2 (MP@ML) (720*512)
    GOP. . . All Allowed, IBBP preferred
    Frames per second. . . . 29.97 (NTSC)
    Stream Type . . . Program Stream
    Audio – MPEG-1, Layer 2 . . . . . . . . . . 384Kb/s Stereo
    Audio – Dolby AC3 . . . . . . . . . N/A
    Digital Audio Level*. . . –20dBfs
    Luminance Level Max. . . . . . . 100 IRE
    Chroma Level Max. . . 120 IRE
    Setup level. . . 7.5 IRE
    Timecode. . . Not Used
    Can anyone help me by letting me know if Encore can do this? And if not, point me in the direction of a program that could?
    Thanks!!
    Samuel Smith replied 16 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
