Activity › Forums › VEGAS Pro › Using an External GPU with Vegas Pro
  • Using an External GPU with Vegas Pro
    Posted by Justin Beaton on February 11, 2024 at 12:43 am
    I’ve searched everywhere, so I’m assuming it isn’t possible, but I wanted to at least inquire. Can you use an external GPU with Vegas Pro (I have Vegas Pro 18) to speed up rendering large projects? If so, can you recommend any that work well with Vegas? Thanks so much!
    Steve Rhoden replied 2 years, 7 months ago 3 Members · 2 Replies
  • Hector Vera
    February 12, 2024 at 2:43 pm
    I believe with the GPU Acceleration option on your Vegas Pro 18, you can certainly use that in order to speed up the rendering process for your large video.
    The steps to do it are the following: Go to the Options Menu in Vegas, then go to Preferences and then click the Video tab, then click the drop down where it says GPU Acceleration, if you have a compatible graphics card on your PC, it should appear on the menu. Then click OK.
    Here is a video I found to help you on that: https://www.youtube.com/watch?v=l3qLvN0CN_w It may say Vegas 17 but it should be the same process for Vegas 18 as well. 🙂 Good luck!
  • Steve Rhoden
    March 3, 2024 at 7:55 pm
    For External GPU acceleration, i kinda doubt such a thing would work with Vegas Pro.
