Activity › Forums › Adobe Premiere Pro › Using AIFF files for audio, only resetting when sliced
  • Using AIFF files for audio, only resetting when sliced
    Posted by Mikkell Khan on August 6, 2010 at 6:47 pm
    Hi, I am using AIFF Audio in my project file that was cleaned up by a sound engineer. However, it seems that whenever I cut the audio and restart Premiere, the audio track where I cut restarts the entire track from there, this happens once or twice. This is becoming very annoying and I would like to know why this is happening and would I need to go to another format like wav to do this editing?
    Mikkell Khan
    Director
    Diamond Films Ltd. (Trinidad and Tobago)
    Todd Kopriva replied 16 years, 1 month ago 2 Members · 3 Replies
  • Todd Kopriva
    August 7, 2010 at 2:47 am
    There is a known bug in Premiere Pro CS5 with AIFF files. See this document. The solution for the moment is to transcode audio to WAV or some other format.
    There is a fix for this bug in the works.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Mikkell Khan
    August 7, 2010 at 7:41 pm
    Thanks. That’s very unfortunate that this is happening as I modified the audio for almost half of our film already with the corrected aif file. I will be changing to the converted wav file from this point and hopefully there will be no more mess ups.
    Mikkell Khan
    Director
  • Todd Kopriva
    September 4, 2010 at 12:06 am
    The Premiere Pro CS5 (5.0.2) and After Effects CS5 (10.0.1) updates are available:
    https://bit.ly/9ex5Cf
    These updates address the AIFF issue. After you’ve installed the update, please let us know whether it works for you.
    If you have any problems with the update, or if you have bugs to report after you’ve installed the update, please let us know through the usual channels:
    https://bit.ly/93d6NF
