Activity Forums VEGAS Pro Using After Effects & Vegas
  • Using After Effects & Vegas
    Posted by Thayer Radic on January 6, 2009 at 6:04 pm
    What is a common workflow used to combine after effects graphics/titling/effects with
    NLE work done in vegas?
    Do most lock picture in vegas and then import in AE or import separate clips into AE for affects and picture lock?
    or
    Do all AE work first and edit in vegas?
    Thayer
    Sameer Mohammed replied 17 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • John Rofrano
    January 6, 2009 at 7:00 pm
    I would imagine everyone’s workflow is a little different and you may change your workflow depending on the project but usually I will work in Vegas and then export media as needed to work in AE and then bring the results back into Vegas.
    If I’m using AE for an opening, then I may create the whole thing in AE or I may create an overlay in AE and render as a Quicktime Animation file (because it supports an alpha channel) and then I’ll just use those assets in Vegas as needed. Clearly for anything that involves motion tracking in the middle of a project and such I will do the former and export from Vegas, work in AE, and render back out as needed.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Steve Rhoden
    January 6, 2009 at 8:26 pm
    As John said it varies with the particular project you are
    working on and an individuals preferred work-flow…for me,
    I most often however create my visual effects sequences first
    in after effects, export using the quicktime format and then
    bring everything into Vegas for finishing.
    Steve Rhoden
    (Cow Leader)
    Creative Arts Director and Film Maker.
    Portfolio at:
    http://www.youtube.com/hentys
  • Sameer Mohammed
    January 26, 2009 at 12:02 pm
    I was also looking for the same information. Thank you for the info. It would be much appreciated if you could explain the workflow a little more.
    Suppose I have a HDV (M2T) clip. I want to do color corrections, special effects or film look in AE and edit in Vegas. What conversions should I make. What should be my best workflow.
    Thanks in advance,
    Sameer
  • John Rofrano
    January 26, 2009 at 1:24 pm
    Color corrections, special effects, and film look are very different things. I would do all of my editing in Vegas first and then render a final version for color correcting or film looks in AE. That is unless you have a two camera shoot and need to color correct one camera which I would do first before editing. Special effects would be handled as needed depending on the FX. Usually I would render a section of the project in Vegas, add the FX in AE, then overlay the FX for that section back in Vegas on a higher track so that the original events are still there on the lower track in case I need to change them later.
    ~jr
  • Sameer Mohammed
    January 26, 2009 at 5:27 pm
    Dear John,
    Thanks for the tip. It has cleared some of my doubts.
    Which is the best format/settings to use when you render from Vegas to work in AE? And also the best settings used when you render after applying effects.
    Regards,
    Sameer
  • John Rofrano
    January 26, 2009 at 5:47 pm
    I use CineForm to render out of Vegas and back from AE unless I need transparency when coming back from AE in which case I will use Quicktime with the Animation codec.
    ~jr
  • Sameer Mohammed
    January 27, 2009 at 4:28 am
    Thank you John for sharing the knowledge. This is only forum where I have got such a quick response. Keep it up.
    Regards,
    Sameer
