Activity Forums Avid Media Composer Using After Affects to create a matte key for Avid?
  • Using After Affects to create a matte key for Avid?
    Posted by Luxdeluks on September 26, 2007 at 5:58 pm
    Hi.
    Couldn’t find an answer through search except partial solutions so if someone could help me establish a workflow for what I want to do would be great.
    Goal is to isolate an object, for example a face/sword and then apply nice filters to it like glow or shatter inside Avid.
    I managed to partially achieve this with the combination of Animatte and then exporting it as PICT, overwriting the Animatte, replacing the fill and then adding the effect with “apply to title/matte” turned on. Problem with this is that exporting to PICT exports only 1 frame and I have the Animatte keyed to the motion, so it would be pretty tiresome to export/import thousands of frames.
    As I understood by reading some posts, that this could be done in After Effects (keying the isolated part) and then exporting as a matte key for Avid Import? I’m kinda an AE newbie so if someone could clear this up or perhaps have another solution I would be very grateful!
    Cheers!
    Jon Zanone replied 19 years ago 2 Members · 1 Reply
  • Jon Zanone
    September 27, 2007 at 10:43 am
    You could certainly do it in AE. My first thought is to use a matte. You’d have to do it frame by frame, and depending on how long the sequence is, ouch. I obviously don’t know what your footage looks like, so I don’t know if you could key it, or use blending modes, or a combination of the two.
    I’d highly recommend getting an AE book by Chris and Trish Meyer – Creating Motion Graphics in After Effect. It’s an amazing resource. You can go through step by step or, like I do, cherry pick what I need and go from there. I would recommend going through the basics chapter to get down moving the cursor, short cuts, etc.
    And of course as I was posting, I noticed the Cow still has its affiliation with Amazon – https://astore.amazon.com/creatnetcreat-20/detail/0240809386
    Buy it through here and support Bessie!
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
