Activity › Forums › Adobe After Effects › Using AE to Export files for print
Posted by Steven Benton on September 22, 2005 at 8:57 pmHello Everybody!
I need to create a 62″X38.5″ 200 dpi print from files that were created in
AE 6.5. I’m guessing the source files need to be precomped into a 12400X7700
comp? I’m also not sure of what output setting to use.Thanks in Advance
SteveJeff Dobrow replied 20 years, 12 months ago 4 Members · 11 Replies -
Daniel Martinez
September 22, 2005 at 9:11 pmI would use tiff with no compresion. Or targa.
Set your workarea to 1 frame and “file -> export image sequence” Youl get 2 frames out of it. Just delete the last.
Jeff Dobrow
September 22, 2005 at 9:22 pmUse ‘save frame as’……alot quicker than fussing about with work area and sequence rendering…..
Daniel Martinez
September 22, 2005 at 9:27 pmAbout the dpi – then you are right.
62″ x 38.5″ | 200 dpi –> 12400 x 7700
Daniel Martinez
September 22, 2005 at 9:34 pmSave frame doesn’t give you the option to save as targa or tiff. Only as PSD. Which is good when wanting PSD file obiously. But when taking to print, maybe Targa or tiff is better.
But ofcourse you can save the frame as… And spare the fideling with the work area.
Steve Roberts
September 23, 2005 at 3:05 amSave Frame As allows you to save as just about anything you want, since it sets up the render queue. Just click on the blue “Photoshop 32-bit” Output Module text to change the setting.
Steve
Jeff Dobrow
September 23, 2005 at 1:08 pmyup. Save frame as allows full saving functionality, only without having to deal with workspace issues. It is great for snapping off differant points in time of the timeline as it saves the pic wherever your timeline marker is positioned……….
Daniel Martinez
September 23, 2005 at 1:16 pmstrange when I “save frame as…” it seems like I only get the option for PSD.
Jeff Dobrow
September 23, 2005 at 1:39 pmSure you are not using ‘save frame as’ -> photoshop layers??
The “‘save frame as’ ->File, brings up the nomral render output window where you can select any output/render settings you wish……..
Daniel Martinez
September 23, 2005 at 3:07 pmIt didn’t for me. I didn’t choose “save frame as -> ps layers”
I chose “save frame as” and got straight to the save file dialog-box with the filetype preset to PSD.
No means of changing that there. I must confess that I havent investigated it futher or to the end.
