Activity › Forums › Adobe After Effects › Using AE to Export files for print
Jeff Dobrow replied 20 years, 12 months ago 4 Members · 11 Replies
Jeff Dobrow
September 23, 2005 at 4:08 pmHmmm….well in AE6.5, under “Composition” there is a “save frame as”, if you highlight it, a dropmenu appears to the right where you must either choose “file” or “photoshop layers”.
If you choose “file” it pops open a standard Render Queue dialog box, now the output module says “photoshop”,….but just like any other usage of the Render Queue you can simply change that to whatever you wish.
If your’s does not operate that way, then I have no clue what the issue may be…..
Good luck!
