Activity Forums Adobe After Effects Expressions Using a slider to control key frames but I also want to add bounce expression?
  • Using a slider to control key frames but I also want to add bounce expression?
    Posted by James Baron on September 13, 2017 at 8:35 am
    Hi there,
    Im using this expression to control the second value key frame
    if (numKeys > 1){
    t1 = key(1).time;
    t2 = key(2).time;
    v1 = 0;
    v2 = comp(“INPUT”).layer(“CONTROL”).effect(“Zoom intensity”)(“Slider”);
    linear(time,t1,t2,v1,v2);
    }else
    value
    But I would also like to have the bounce expression added to the key frames.. Is this possible?
    Thanks in advance
    James
    Juanluis Vich replied 8 years, 10 months ago 2 Members · 1 Reply
  • Juanluis Vich
    November 5, 2017 at 4:31 am
    hi!
    I’m having the same issue, did anyone get it to work?
    thanks!!
