Activity Forums Adobe Premiere Pro Using a chroma green rug on a floor for green screening?
  • Using a chroma green rug on a floor for green screening?
    Posted by David Dinenna on July 1, 2010 at 4:07 pm
    I’ve convinced my company to finally dedicate a room in our building for green screening our video (up to now we’ve been using a portable green screen).
    I’ve requested we paint one entire wall chroma green and then also come out from the wall about 10 feet and paint that chroma green on the floor. They’re not too willing to do the floor, but wanted to know if they could install a chroma green carpet on the floor instead. Are there chroma green rugs and does anyone know if this would work?
    Thanks.
    Anthony Wong replied 16 years ago 6 Members · 5 Replies
  • Alan Lloyd
    July 1, 2010 at 5:19 pm
    Not sure if that exists, though I’d wonder about anything textured giving a clean key.
  • Brian Louis
    July 1, 2010 at 8:42 pm
    A rug may give too much texture as per Alan, you could use a continous sheet of green muslin drapped down the wall and out into the room, this will eliminate the join where the wall meets the floor, or if painting the wall you can round the joint between the wall and floor with Mud(drywall spackle) to eliminate it before painting the floor and wall.
  • Kerry Brown
    July 3, 2010 at 3:01 am
    Use tempered masonite on the floor painted with the same chroma green as the wall. You could also make a curve with it at the wall and mud the seam for a smooth edge,
    KB
  • Jeff Brown
    July 5, 2010 at 2:47 pm
    You can find Chroma Green fabric from many sources (check B&H photo or Markertek). Another way to work with full green is to build a platform about 10 to 20″ high, and large enough for your talent (6×6′ maybe), and paint the top green. The less green you have in the room, the easier it will be to clean up spill. Having a raised platform should let you “overlap” the floor/wall green in the shot.
    -Jeff
  • Anthony Wong
    August 22, 2010 at 5:03 pm
    I may be a bit late in responding to this thread, but Rosco does have a Chroma Floor product (https://www.rosco.com/us/video/chromaflr.cfm)
    -Anthony
