Using a 7.7in Small HD OLED HDMI/SDI Monitor to externally monitor/ Color Correct on the Road
Hi!
I was hoping someone can weigh in on using a small OLED monitor to color correct on the fly with Davinci Resolve.
Right now I have the Small HD AC7 OLED HDMI/SDI 7.7in monitor. It is used for monitoring while shooting. I may upgrade to their new DP7 monitor when it comes out. I was told that the monitor is calibrated to Rec 709 by SmallHD.
Has anyone tried to Color Correct on the fly using one of these small monitors? I was wondering about this for times when I am on the road and don’t have a Panasonic 17in, etc around to color off of.
Would you do some additional calibration on this monitor (and how would you go about it)?
Is this a possible solution for lightweight on location grading?
– DT
