Activity Forums Avid Media Composer user privileges insufficient to start a low level driver
  • user privileges insufficient to start a low level driver
    Posted by Jose Moris on June 22, 2008 at 9:20 pm
    I am trying to open up audio suite in my Avid Xpress Pro 5.8.3. I keep getting a message that says: user privileges insufficient to start a low level driver. When I click ok the audio suite panel opens and says that the DAE is not connected. Is there a way to fix this?
    Joshua Finn replied 16 years, 9 months ago 5 Members · 4 Replies
  • Michael Phillips
    June 22, 2008 at 10:07 pm
    Try a re-install – seems the DAE is missing.
    Michael
    Michael Phillips
  • Jose Moris
    June 23, 2008 at 10:02 pm
    I’m running the software on Windows Vista. Could that be an issue?
  • Michael Hancock
    June 23, 2008 at 10:23 pm
    Very likely. Xpress Pro isn’t qualified to run on Vista. You’ll need to downgrade to XP Pro 32bit, or upgrade your Xpress Pro to Media Composer 3.0 ($495 upgrade) to use Vista, and it requires Vista Business, I believe.
    Michael.
  • Joshua Finn
    November 21, 2009 at 5:16 am
    Hi
    I am running media composer 3 on vista 64 and having the same error appear. Would love to know if you found an answer to the problem
