Activity Forums Panasonic Cameras User coments on Panasonic AG-HPX500 pls?
  • User coments on Panasonic AG-HPX500 pls?
    Posted by Peter Dorr on July 14, 2007 at 11:10 pm
    I am considering buying an HD camera.
    So far the Sony F350 (1/2″) was the camera of choice, but after reading some of the specs of the new Panasonic AG-HPX500 I was pretty amased at the price/quality of this cam.
    Any user feedback? Is it really a very good HD camera?
    Which lens would you recommend?
    thnx for your help, much appreciated.
    Peter
    Peter Dorr
    G.a. Kokes replied 19 years ago 9 Members · 13 Replies
  • 13 Replies
  • Noah Kadner
    July 15, 2007 at 3:20 pm
    Recommend a Fujinon or Canon HD lens- spend a lot for a good lens and you’ll be rewarded. I’ve shot with this and it’s a really amazing camera at this price or even double this price.
    Noah
    Unlock the secrets of the DVX100 and Final Cut Pro!
    https://www.callboxlive.com
  • John Fishback
    July 16, 2007 at 12:59 am
    We’ve had our HPX500 since the middle of June. Since then we’ve shot two projects with it. The quality is amazing. It’s extremely flexible. We use the Panasonic 17″ broadcast monitor (also amazing) and the remote camera control unit. We’ve tested many of the HD options and have shot both 24 and 30p. The dynamic range of the image is breath-taking. It’s very important to plan your workflow before shooting. I have not shot with other HD cameras so I can’t compare it to competing products.
    John
    Dual 2.5 G5 4 gigs RAM OS 10.4.8 QT7.1.3
    Dual Cinema 23 Radeon 9800
    FCP Studio 5 (FCP5.1.2, DVDSP4.1.1, Comp2.3, STP1.1, Motion 2.1.2)
    Huge U-320R 1TB Raid 3 firmware ENG15.BIN
    ATTO UL4D driver 3.50
    AJA IO driver 2.1 firmware v23-28
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neuman U87s, Genelec Monitors, PrimaLT ISDN
  • G.a. Kokes
    July 16, 2007 at 11:25 am
    Peter,
    It is my observation that the HPX500 is at its best when using a “true” HD lens.
    Good luck.
    G.A.
    Aurora Coast Productions
    HD and 35mm Cinematography
    NJ Tri-State Area
    http://www.AuroraCoast.com
  • Bob Cole
    July 16, 2007 at 10:03 pm
    [G.A. Kokes] “the HPX500 is at its best when using a “true” HD lens.”
    Several of you report that one should get an HD lens. Acc. to Pana’s literature, there are special HD lenses for this camera which compensate for some imaging problems.
    Are those the lenses you are referring to? Which exact lens do you folks use and recommend?
    — Bob C
  • Seth Melnick
    July 17, 2007 at 6:33 pm
    Here is a review I wrote about the hpx500 – https://www.slmproduction.com/mainsite/journals/reviews/
  • Matt Gottshalk
    July 18, 2007 at 12:02 am
    IMO, the CAC lenses are a huge compromise packaged with the camera in order to allow people to buy a complete camera system at a resonable price.
    If you are serious about buying this camera, as other have said, do yourself a favor and get a quality lens, which in this case, starts at about twice of the price of the camera head itself.
    The difference is easily noticeable.
  • G.a. Kokes
    July 18, 2007 at 11:28 am
    Bob,
    A “Tru” HD lens will give you an increase in resolution over any of the packaged lenses. Matt is correct in his statement above.
    Depending on what you plan on shooting and delivering on, however the packaged lenses may be just fine.
    G.A.
    Aurora Coast Productions –
    HD and 35mm Cinematography –
    Drama, Documentary, Commercials and Events NJ/Tri-State Area
  • Bob Cole
    July 18, 2007 at 2:40 pm
    [Noah Kadner]
    Recommend a Fujinon or Canon HD lens- spend a lot for a good lens”
    Very interesting discussion everybody. I was under the wrong impression. I thought that the “cheap” glass, which has CAC, was to correct an imaging weakness in the 500 itself.
    I assume that the way to “decode” the lens manufacturers’ websites is to look for an EFP lens?
    Has anybody used the Canon HJ11ex4.7B? The wide angle sounds very useful.
    — Bob C
  • John Fishback
    July 18, 2007 at 3:05 pm
    While I agree completely that better glass is always preferable, I suggest that anyone interested in this camera give it a test drive. While the entire package is a compromise with smaller sensor, reduced feature set, etc. compared to higher-end cameras, the results are terrific. For our level of production the package is an enormous step up from Betacam. The images are sharp! I can see individual hairs on people’s heads (a makeup challenge). Check out the screen shots in the review above. If you really need true HD glass, this might not be the camera for you.
    John
  • Accountclosedduetopolicyviolations
    July 18, 2007 at 10:24 pm
    [John Fishback] “While the entire package is a compromise with smaller sensor, reduced feature set, etc. compared to higher-end cameras, the results are terrific.”
    Smaller sensor,reduced feature set??
    Are talking about HPX-500??
    2/3′ sensor,variable frames,different formats,all the outputs…..
    apart from megapixel block it has got more features when cameras 2-3 times its price..
