Activity Forums Apple Final Cut Pro Legacy used wrong aspect ratio to upconvert with AJA LHi card, can I fix it with Distort tab in FCP7???
  • used wrong aspect ratio to upconvert with AJA LHi card, can I fix it with Distort tab in FCP7???
    Posted by Nick Natteau on August 20, 2011 at 3:03 am
    After upconverting a bunch of WWII stock footage delivered to me on NTSC mini-DV tapes, I realize that I used the wrong aspect ratio to up convert. In my Kona LHi AJA menu I should have selected Pillarbox 4:3. Instead it was set to Anamorphic.
    So my question: Do I have to offline everything and re up convert using “Pillarbox 4:3”?
    Or is it exactly the same if I simply go into my FCP7 Motion-Distort tab, and select “33.33” for the aspect ratio, thereby giving me the 4:3 pillarbox aspect ratio???
    Thanks in advance for your feedback.
    David Roth weiss replied 15 years ago 2 Members · 3 Replies
  • David Roth weiss
    August 20, 2011 at 3:22 am
    [Nicholas Natteau] “is it exactly the same if I simply go into my FCP7 Motion-Distort tab, and select “33.33” for the aspect ratio, thereby giving me the 4:3 pillarbox aspect ratio???”
    No, it’s not “exactly” the same, but you will not be able to discern the difference, so it’s “effectively” the same.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    Don’t miss my new tutorial: Prepare for a seamless transition to FCP X and OS X Lion
    https://library.creativecow.net/weiss_roth_david/FCP-10-MAC-Lion/1
    Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
  • Nick Natteau
    August 20, 2011 at 5:19 am
    So need to re up convert then. Thanks David, you just saved me hours of work!
  • David Roth weiss
    August 23, 2011 at 1:20 am
    Glad to help Nicholas…
    David Roth Weiss
    Los Angeles
