Activity Forums Apple Final Cut Pro Legacy use of database to update titles
  • use of database to update titles
    Posted by Kevin Clark on May 16, 2011 at 2:04 pm
    is there any product or plug in out there that can refer to a database to update title information? i have a show that i produce twice per month, and the majority of the work is updating titles… there should be a way to do this automatically… sort of like a dynamic website. thoughts or ideas?
    thanks
    kevin clark
    Bouke Vahl replied 15 years, 4 months ago 2 Members · 3 Replies
  • Bouke Vahl
    May 16, 2011 at 2:28 pm
    I’ve once made such a thing for Motion.
    A Motion file is a simple XML file that can be altered to your liking.
    So if you can create your titles with Motion, yes, it is possible.
    Other text generators in FCP can be controlled as well, but Boris titles are hard to do.
    Exactly what titles do you have, and in what format is your database?
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
  • Kevin Clark
    May 16, 2011 at 2:34 pm
    the show is a real estate show, and the database is generated from the local multi-list system… i used the csv export to get the data (PRICES, ADDRESSES, ETC.) to our server for a dynamic webpage.
    i designed the template in motion, and use that template within fcp.
    maybe i should post this in the motion forum?
    thanks
    kevin clark
  • Bouke Vahl
    May 16, 2011 at 2:37 pm
    Checking the motion section can never harm.
    You can also contact me direct if you want something custom made.
    Bouke at videotoolshed dot com.
    hth,
    Bouke
