Activity › Forums › Compression Techniques › use FFMPEG to mux and channel mix with DOLBY E tracks?
  • use FFMPEG to mux and channel mix with DOLBY E tracks?
    Posted by Steve Smith on October 1, 2012 at 2:09 pm
    We are looking at FFMPEG as a way to create a ProResHQ.mov with two streams of DOLBY E.
    From what I’ve read, FFMPEG cannot encode DOLBY E, but I’m wondering
    if we could use FFMPEG to mux in DOLBY E if the tracks exist as separate WAV files?
    I have no experience using FFMPEG, so I’m hoping someone here can offer some guidance
    on whether or not this workflow is even possible.
    The source files are ProResHQ.MOV with 16 discreet tracks (5.1+2, 5.1+2),
    and the target files are XDCAM HD.MXF with 8 tracks (St Full MX, St Mix Minus, DOLBY E, DOLBY E)
    Full details below, any help or suggestions would be great, thanks!
    ProRes HQ. MOV [SOURCE FILE]
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID: qt
    Overall bit rate mode: Variable
    Writing library: Apple QuickTime
    Format: ProRes
    Format profile : High
    Codec ID: apch
    Bit rate mode: Variable
    Bit rate: 168 Mbps
    Width : 1 888 pixels
    Original width: 1 920 pixels
    Height : 1 062 pixels
    Original height: 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode: Constant
    Frame rate: 25.000 fps
    Color space : YUV
    Chroma subsampling: 4:2:2
    Scan type: Interlaced
    Scan order: Top Field First
    *16 discrete audio tracks
    *Dolby E in sync
    *24 bit audio
    01 -5.1 Full Mix – Left
    02 -5.1 Full Mix – Right
    03 -5.1 Full Mix – Center
    04 -5.1 Full Mix – LFE
    05 -5.1 Full Mix – Left Surround
    06 -5.1 Full Mix – Right Surround
    07 -Stereo Full Mix – Left
    08 -Stereo Full Mix – Right
    09 -5.1 Mix Minus – Left
    10 -5.1 Mix Minus – Right
    11 -5.1 Mix Minus – Center
    12 -5.1 Mix Minus – LFE
    13 -5.1 Mix Minus – Left Surround
    14 -5.1 Mix Minus – Right Surround
    15 -Stereo MDE- Left
    16 – Stereo MDE- Right
    XDCamHD .MXF [TARGET FILE]
    Format : MXF
    Format_Commercial_IfAny: XDCAM HD422
    Format profile: OP-1a
    Format settings: Closed / Complete
    Overall bit rate mode: Constant
    Format: MPEG Video
    Format version: Version 2
    Format profile: 4:2:2@High
    Bit rate mode: Constant
    Bit rate: 50.0 Mbps
    Width : 1888 pixels
    Original width: 1920 pixels
    Height: 1062 pixels
    Display aspect ratio: 16:9
    Color space: YUV
    Bit depth: 8 bits
    Scan type : Interlaced
    Compression mode : Lossy
    *8 audio tracks
    *Dolby E in sync
    *20 bit audio
    01- Stereo FullMix – Left
    02- Stereo FullMix – Right
    03- Stereo MDE- Left
    04- Stereo MDE- Right
    05- DOLBY E Full Mix
    06- DOLBY E Full Mix
    07- DOLBY E MixMinus
    08- DOLBY E MixMinus
    Reuben Martin replied 14 years ago 2 Members · 1 Reply
  • Reuben Martin
    October 3, 2012 at 12:28 am
    Supposedly Dolby-E can be muxed in and treated like a stereo audio track, however I’m not sure if MXF has special metadata tags used to indicate that the audio track is Dolby-E. I doubt FFMpeg supports it. A lot of work has gone into fixing MXF encoding and decoding over the last 6-9 months, but I’m not sure Dolby-E has been part of that. Mostly because Dolby-E encoders are not very commonly available to test with.
    You might try asking in the ffmpeg developer list. If you have access to such an encoder as well as another tool to properly mux it into an MXF, I’m pretty sure they would love to get their hands on some samples they could play with.
    https://lists.ffmpeg.org/mailman/listinfo/ffmpeg-devel/
