Activity Forums Adobe After Effects Expressions Use a slider to move between keyframes of a precomp
  • Use a slider to move between keyframes of a precomp
    Posted by Christopher Handrick on April 10, 2013 at 3:24 pm
    Hello,
    Is there a way to use a slider to set the position of the playhead in a precomped layer?
    basically what I’m trying to do is create a number of preset keyframes, say a variety mouth shapes for example, inside a precomp, and then apply a slider to that precomp that controls what frame should be displayed
    I’ve gotten a similar end result in flash using nested symbols, and was wondering if expressions could be used to accomplish this in After Effects.
    Dan Ebberts replied 13 years, 4 months ago 2 Members · 1 Reply
  • Dan Ebberts
    April 10, 2013 at 5:42 pm
    Yes, that should work fine. Remember that a time remapping expression expression expects its results in seconds, so if your slider represents a frame number you need to use framesToTime() to convert it to seconds.
    Dan
