Activity Forums Adobe After Effects Expressions Use a slider to change a certain keyframe’s value
  • Use a slider to change a certain keyframe’s value
    Posted by Matias Andersen on January 23, 2018 at 7:08 pm
    I’m trying to do some simple position animation with keyframes, but I want to be able to change the 2nd keyframe’s X & Y values with a slider.
    I haven’t been able to find an expression that does that, and I have little to no skills in coding, I only know the basics.
    Just to clarify, I only want the 2nd keyframe’s values to change, I don’t want the expression to change the position of the layer itself, since I still want the keyframe animation.
    I found an expression here which kind of does what I need, exept that it doesn’t keep the keyframe’s animation.
    valueControl = thisComp.layer("Adjustment Layer 2").effect("Slider Control")("Slider")
    valueKey = 2
    n = 0;
    if (numKeys > 0) {
    n = nearestKey(time).index;
    if (key(n).time > time) n--;
    if(n==valueKey){
    value-valueControl} else value;
    Matias Andersen replied 8 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
