Activity Forums Adobe After Effects Use a comp as “texture” for a shape’s extrusion
  • Use a comp as “texture” for a shape’s extrusion
    Posted by Jerome Laville on February 6, 2023 at 1:58 pm
    After having extruded a shape, is there a way to “project” something onto the extrusion?
    By default the extrusion will use the same colour as the shape. Instead, I would like to use it to show a video — think of it as a wall onto which a film is projected.
    I suppose this would be similar to the famous Marvel intro (starts at 17 seconds https://youtu.be/k1547CezWqQ?t=17).
    I could find a way to use it as a mask, but of course the video wouldn’t adjust to the shape’s depth and curves, and that would be especially noticeable if I projected it onto text (e.g. the letter O).
    Many thanks.
    Jerome Laville replied 3 years, 7 months ago 2 Members · 2 Replies
  • Walter Soyka
    February 7, 2023 at 1:38 pm
    I don’t think there’s a way to do this with extruded shape layers in After Effects. You’d be better off using Video Copilot’s Element 3D plugin, or doing this in C4D.
  • Jerome Laville
    February 7, 2023 at 4:07 pm
    That makes sense to me. Thank you for taking the time to reply!
