Activity › Forums › Audio › USB iMic
  • Sounds like the iMic is dying.
    Mine did.
  • Alexander Kallas
    June 5, 2006 at 9:59 am
    Thanks Matte,
    I’m stuck, can’t redo VO, talent has left.
    Any recommendations on software to clean up this crackley audio?
    I’ve tried STP clicks and pops fix, doesn’t really do it.
    Cheers
    Alexander
  • Bouncing Account needs new email address
    June 5, 2006 at 11:19 am
    Clean up the worst ones MANUALLY (takes a lot of time).
    Then you might try Bias SoundSoap 2. ($80-$100)
    https://www.bias-inc.com/products/soundsoap/
    You sample the noise “in the clear” and the software “removes” it throughout the rest of the clip(s).
    The problem with INTERMITTENT (non-continuous) noise, is the software has a much lower ability to distinguish the noise from the wanted program material.
