Activity Forums Storage & Archiving USB 3.0 PCI ExpressCard/34 Adapter for my early 2011 17 inch Macbook Pro?
  • USB 3.0 PCI ExpressCard/34 Adapter for my early 2011 17 inch Macbook Pro?
    Posted by Samantha Bode on September 15, 2016 at 1:12 pm
    Hello all!
    I am currently using USB 3.0 hard drives for a project. My early 2011 17 inch Macbook Pro only has hubs for USB 2.0. My timeline in Premiere Pro CC 2015 is lagging, and I am wondering, if I install a USB 3.0 PCI ExpressCard/34 Adapter into my express slot and use my USB 3.0 hard drives with those hubs, will this help with the read/write speed of my hard drives?
    If so, can you recommend and adapter?
    Samantha
    Rob Alexander replied 9 years, 8 months ago 4 Members · 6 Replies
  • Steve Grappone
    September 21, 2016 at 6:54 pm
    I think it maybe time to look at t-bolt options. I know Promise makes a great device.
  • Samantha Bode
    September 21, 2016 at 7:02 pm
    Thank you so much for your response, Steve!
    I am having trouble locating what you are referring to. Would you happen to have a link to the product, or some good terms to be able to search it? Right now, I am only coming up with card readers.
    To give you an example of what I was looking for in terms of the USB 3.0 adapter: https://eshop.macsales.com/item/Sonnet%20Technologies/USB32PMAE34/
    Samantha
    Samantha Bode
  • Steve Grappone
    September 21, 2016 at 7:04 pm
    My recommendation was not to use USB 3.0 I would use the Thunderbolt connection that is already on your mac and use a raided system such as this:
    https://www.promise.com/products/Pegasus/Pegasus2
    Hope this helps.
  • Samantha Bode
    September 21, 2016 at 7:07 pm
    Oh, ok! Thanks. I am currently on a really, really tight budget.
    In your personal opinion, do you think it’s worth trying to get the USB 3.0 adapter?
    Samantha Bode
  • Chris Sebes
    October 14, 2016 at 4:43 pm
    If budget is very tight and you’re currently editing with USB3 drives, I’d go with the adapter. Buying a shiny new RAID system is wonderful, but expensive. Something like that Pegasus 2 starts at $1400. The USB3 speeds are very fast and a huge step up from the USB2 speeds. You should easily notice the difference.
    Chris Sebes
    Senior Video Editor
    https://www.MediaMixStudios.com
  • Rob Alexander
    January 5, 2017 at 2:34 pm
    As mentioned below, your drives should be up to it. USB 3 expresscards were a bit finicky on the macbooks – I have a caldigit one which has worked well but is no longer available. I suggest you look to something like the Caldigit TS2 which connects to your thunderbolt port and adds USB3, esata, ethernet and HDMI. A great little device!
