Activity Forums Adobe InDesign URGENT – Pasting Problem
  • URGENT – Pasting Problem
    Posted by Alexis Kyprianou on December 7, 2007 at 9:00 am
    Dear users of InDesign,
    I have a strange problem and I need your urgent help.
    When I cut/copy and then paste, the item I am copying does not constrain the dimensions it had before copying. It becomes really huge.
    Is it a setting? the strange thing about it is that doesn’t happen all the time.
    I would appreciate your help a lot.
    Thank you in advance,
    Alexis Kyprianou
    Alexis Kyprianou replied 18 years, 8 months ago 2 Members · 2 Replies
  • Jacki Schklar
    December 21, 2007 at 12:35 am
    Are you copying from another place in that same document or from another doc? What version of InDesign?
    If you do a search in your help menu on “clipboard preferences” or “paste with formatting” or “pasting text attributes” you will probably find what you need.
  • Alexis Kyprianou
    December 21, 2007 at 7:05 am
    I am copying from the same document. I’s a CS2 version and it happens whatever I copy, images, text etc. The help menu doesn’t have any results under the phrases you mentioned. I am just copy-pasting. As I said before. the strange thing is that it doesn’t happen all the time.
    Thank you for your time anyway
