Activity Forums Adobe After Effects URGENT help please on a deadline – seperate comp effects
  • URGENT help please on a deadline – seperate comp effects
    Posted by Omnivl on April 26, 2006 at 10:54 am
    I have a PSD with the following effects, drizzle, wave warp, blur. My
    problem is that the wave warp effects the drizzle and it looks really
    bad, is there any way that each effect can be independant of each other
    so they do interfere with each other.
    thanks
    Steve Roberts replied 20 years, 4 months ago 3 Members · 2 Replies
  • Travis Turner
    April 26, 2006 at 1:58 pm
    I’m not sure I completely understand the problem but if I understand correctly the solution could be as simple as this – you could duplicate your layer pre-effects – then apply the effects separatly to each layer – or another solution would be to render a .mov with the drizzle effect applied , then import the mov and apply the wave warp – hope that helps
  • Steve Roberts
    April 26, 2006 at 2:00 pm
    Did you try reversing the order of the effects in the effect window? (F3)
    You can’t make them independent, but you can change their order for a different look.
