Activity Forums AJA Video Systems Urgent: Downconverting from HDV to Digi Beta – Kona 2
  • Urgent: Downconverting from HDV to Digi Beta – Kona 2
    Posted by Daniel Elder on May 19, 2008 at 2:06 pm
    Hi, I am doing tests right now from my downconvert from 1080 60i sequence to my Digi Beta deck. The settings I have in Kona 2 CP are:
    Primary setting: 1080 29.97
    secondary setting: 525 29.97
    Downconvert: anamorphic
    Then my SDI out is through the primary. Everything works no problem, but I am losing MAJOR Quality on the downconvert. I am monitoring it through a Panasonic BT-LH1700 as well as a Sony Bravia monitor and both share the same results when on the 480i output. This needs to be mastered today, I’m worried about the quality, can someone guide me through this safely. Thanks a bunch
    Daniel Elder
    producer
    http://www.luminair.com
    Daniel Elder replied 18 years, 3 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    May 19, 2008 at 4:16 pm
    FCP should be in your HD easy setup and your SDI output should be set for secondary.
    Jeremy
  • Daniel Elder
    May 19, 2008 at 4:37 pm
    Ok, I think I did that and it looked much better, I will let you know if anything goes wrong. Thanks
    Daniel Elder
    producer
