Activity › Forums › Apple Final Cut Pro Legacy › URGENT: Blocks of pixels missing
  • URGENT: Blocks of pixels missing
    Posted by Martin Cote on August 22, 2006 at 4:55 pm
    We just purchased a Xsan and 4 fcp stations, we are experiencing missing blocks of pixels when trying to render a sequence from the SAN. The problem is not happening when we render from the local disk. Could this be a bandwith issue? Should we have a specific folder structure on the SAN, is this a setting problem?? Please help. Thanks
    John Christie replied 20 years, 1 month ago 2 Members · 1 Reply
  • John Christie
    August 22, 2006 at 6:06 pm
    Hi Martin
    I’m guessing you’re running Xsan 1.3. It was a bad release, causing all sorts of render problems, strangely the render problems only seem to affect FCp and photoshop. Xsan 1.4 seems to have solved the problems.
    Check out the discussions on Xsanity.com. There’s also an Xsan forum here on the Cow with some info on Xsan 1.4
    Cheers
    John C
    Keyframes Editing
