Activity › Forums › Apple Final Cut Pro › Upscaling 1080p for DCP …
  • Upscaling 1080p for DCP …
    Posted by Paul Figgiani on March 21, 2014 at 1:35 pm
    I’m sifting through all the steps necessary to create a DCP package with the original footage shot at 1080p. It looks like the information that is out there regarding upscaling is accurate – footage will need to be upscaled by 7%. I want to deliver at 2.39 aspect ratio.
    Instead of letterboxing and then cropping – I find it easier to just work in 2048×858 natively in FCPX. I drop in the 1080p clips with Spacial Conform set to NONE, scale to 107%, and then use Transform/Y Position to reframe the image.
    Next I pull the Master Output file into After Effects and export a 16bit TIFF Image Sequence in preparation for openDCP.
    I was just wondering if anyone has had the chance to view 2K (2048×858) material that has been upscaled from 1080p on a large projection screen? If so how does it look?
    Obviously anytime footage is scaled higher there will be be some level of quality degradation. I’m wondering how 7% upscale will hold up on the big screen …
    thx.
    -paul.
    Paul Figgiani replied 12 years, 6 months ago 2 Members · 2 Replies
  • Simon Ubsdell
    March 21, 2014 at 2:26 pm
    [Paul Figgiani] “I was just wondering if anyone has had the chance to view 2K (2048×858) material that has been upscaled from 1080p on a large projection screen? If so how does it look? “
    We work this way a lot of the time for theatrical movie trailers and it’s usually impossible to tell the difference once projected – however we leave the DCP mastering house to do the upscaling. Not sure how well FCP X manages it but I would make sure you test all your options and find out which looks best.
    Do make sure any graphics are 2048 though as you will notice a difference there.
    Simon Ubsdell
    hawaiki.co
  • Paul Figgiani
    March 21, 2014 at 3:13 pm
    [Simon Ubsdell] “we leave the DCP mastering house to do the upscaling. Not sure how well FCP X manages it but I would make sure you test all your options and find out which looks best.
    Do make sure any graphics are 2048 though as you will notice a difference there.”
    Thanks, Simon.
    So alternatively I could work with 2.39 letterboxed 1080p and 2048 graphics. Then crop the output accordingly and let the DCP mastering house handle the upscaling. Makes sense.
    Thanks again.
    -paul.
