Upscale IMX 50 Pal to HD 720P
I’m working which Final Pro with a project which is setup as an HDV 720P project. In this project I have PAL IMX 50 material which needs to be upscaled to 720P. In Final Cut Pro I used the scale method to do this, but when I view the sequence, the image quality is not great, by which I mean that Final Cut Pro probably does not do a nice rendering of interlaced material in a progessive timeline.
Is there a way to properly upscale PAL material to HD720P?
