Activity Forums Storage & Archiving UPS for Sanman 16 bay raid storage
  • UPS for Sanman 16 bay raid storage
    Posted by Roxanna Turner on July 27, 2011 at 1:54 pm
    Hi everyone, I’m looking for some advice since I’m not overly tech savvy. Could anyone tell me what kind of UPS would be suitable for a Sanman 16 bay raid storage system. On the back of the raid, the only info I could see was 450w on the left side and 450w on the right side. Does this mean that a 1000W ups would be sufficient. We have occasional power trips and I want to make sure that the raid keeps running and is protected. Thanks in advance.
    Roxanna Turner replied 15 years, 1 month ago 3 Members · 3 Replies
  • Bob Zelin
    July 27, 2011 at 4:54 pm
    buy the biggest one you can afford. The big APC is between $500 – $600. For smaller systems, the Tiger Direct “Ultra” series is cheaper and very good.
    Bob ZElin
  • Alex Gerulaitis
    July 28, 2011 at 2:21 am
    [Roxanna Turner] ” On the back of the raid, the only info I could see was 450w on the left side and 450w on the right side. Does this mean that a 1000W ups would be sufficient. “
    The power supplies could be redundant (only one operating at a time) which means a 450VA UPS should suffice – but you’d first want to find out the peak power usage of the array from the vendor.
    Usually (but not always): the higher the VA rating of the UPS, the longer the runtimes – so you’d probably want to choose your UPS depending on the nature of the power trips (long? momentary?).
    Or, like Bob Zelin says, just buy the biggest baddest UPS you can afford. 🙂
    Alex (DV411)
  • Roxanna Turner
    July 28, 2011 at 4:10 pm
    Thanks for the replies 🙂 I don’t have a great budget for the UPS, and shipping for an ups from tiger direct to Australia would be too expensive. I guess I’m just looking for what I could get away with, just powerful enough to keep the raid running for a few minutes while the power gets turned back on or the raid is shut down properly. I will try to get in touch with the vendor but if anyone has a similar Sanman 16 bay raid and has some idea of VA/W that it uses, please let me know. Thanks guys
