Activity › Forums › Apple Final Cut Pro Legacy › Upper or Lower Field?
  • Upper or Lower Field?
    Posted by Jimmy Stewart on March 6, 2007 at 2:11 am
    I shot my short film with the panasonic dvx100b using 16:9, 24p. I am now finishing the edit in FCP. Should I use “upper field” or “lower field”? I am currently in “lower.” And I see the video is broken into lines – only at certain times. I am going to make a final print for a batch of dvd’s to sell, and also a screener for fests and want to make sure that I have the best settings.
    Jim
    Jeremy Garchow replied 19 years, 6 months ago 4 Members · 8 Replies
  • 8 Replies
  • Jeremy Garchow
    March 6, 2007 at 2:14 am
    Did shoot 24p or 24pA.
    If you captured 24pA and are editing in a 23.98 timeline, field rendering should be to to off or none. If you are editing @ 29.97, set it to lower.
    Jeremy
  • Chris Borjis
    March 6, 2007 at 3:00 am
    yeah sounds like a progressive issue.
    if your seeing lines on your computer monitor don’t trust it, only trust viewing on a tube tv or pro crt.
    most DV video is lower field first. I think PAL and one of the matrox or canopus dv codecs is upper though.
    just about everything else is upper field first.
  • Colin Mcquillan
    March 6, 2007 at 6:35 am
    [Borjis] “just about everything else is upper field first.”
    lower you mean
    Colin McQuillan
    Vancouver BC
  • Jimmy Stewart
    March 6, 2007 at 3:27 pm
    thank you all!
  • Chris Borjis
    March 6, 2007 at 5:08 pm
    [Colin McQ] “lower you mean”
    well I guess they might be even since most consumer stuff is lower but all professional stuff is upper. 😉
  • Jeremy Garchow
    March 6, 2007 at 5:50 pm
    PAL Uncompressed is Upper, and 1080i NTSC/PAL frame rates are Upper. Standard Def NTSC is lower (DV and ‘Uncompressed’) as is DV PAL.
  • Chris Borjis
    March 7, 2007 at 1:16 am
    [JeremyG] “Standard Def NTSC is lower (DV and ‘Uncompressed’) as is DV PAL.”
    no.
    Digital Betacam, BetaSP & D2 are all upper field.
    These would all be captured via uncompressed.
    uncompressed doesn’t equate the field order, its the source recording deck.
  • Jeremy Garchow
    March 7, 2007 at 1:20 am
    [Borjis] “uncompressed doesn’t equate the field order, its the source recording deck.”
    I am talking strictly on how FCP handles the media. I never edit digibeta material in upper field first. Ever.
