Activity Forums Adobe Premiere Pro Upper or Lower Field First??
  • Upper or Lower Field First??
    Posted by Russell Tarbox on November 30, 2011 at 11:48 am
    Hi, I have a problem with fields.
    I have some video footage from a dv camcorder.
    The files are in mpg format and I scanned them and they are upper field first.
    What would happen if I render that footage using lower field first?
    I have read that DV is normally lower field first.
    I think the camcorder was bought in the USA.
    Could this be the reason?
    Hope someone can point me in the right direction.
    Ann Bens replied 14 years, 10 months ago 2 Members · 3 Replies
  • Ann Bens
    November 30, 2011 at 4:09 pm
    DV (tape) from a camera is dv-avi with lower field.
    Mpg from a SD (standard def.) probably a dvd camera, is almost always upper field. So make your sequence upper field. Also export to upper field.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Russell Tarbox
    November 30, 2011 at 4:17 pm
    thanks for your help Ann, that really helped me out.
    I wonder if I can ask another question please?
    I did do a few tests and my title looks doubled.
    The title is animated but doesn’t look sharp, it is all distorted.
    Could this be related to the lower/upper field issue?
    I have read that progressive is for motion titles, etc
    If this is the case, would it be ok to create a progressive title with an upper field video?
    I hope that makes sense.
    Thanks again.
    Russell
  • Ann Bens
    November 30, 2011 at 6:11 pm
    A title does not have any fields.
    Might want to read this:
    https://library.creativecow.net/articles/hodgetts_philip/titles.php
